I just noticed this morning that I can get any new scenes to render with V-Ray RT and I think I found out why and just made a new clean scene to test and it still broke.
1. new scene drop in any object " I used a cylinder"
2. add v-ray dome light, add vray HDRI to the light (in my case picked a spherical map)
3. I added a *jpg spherical map to the environment map
4. normal rendering works great and as expected
5. switch to RT and hit render with CPU, CUDA or OpenCL and it will hang for a bit trying to load the ENV map and then crash
6. turn off Use Map in environment dialogue and hit render and it renders as normal.
specs and SW versions in my tag below.
*Edit* Crap this was supposed to go into bugs… Ignore this thread.
