V-Ray RTEngine DLL not found
We’re having some difficulties getting V-Ray RT to work on one of our machines.
We have it work working fine on one, but another (almost identical setup) reports the error “V-Ray RTEngine DLL not found”. I’ve looked in the help file which says this means there is a problem with the install, so I’ve completely re-installed it a number of times but keep getting the same problem.
Any suggestions?
Cheers,
AJ
Please take a look at this thread:
http://www.chaosgroup.com/forums/vbulletin/showthread.php?p=402870#post402870
Let me know if any of the suggestions there work for you.
Yep - typing in “set” and then running 3dsmax from the command line did the trick.
Thanks Vlado.
Ok then, good to know.
