V-Ray scene within a scene.
Hi thomas_bussey,
The nested VRscene is supported with Vantage 2.0. Can you please send us the project so we can investigate what is not working in your case?
Alexander
Hi Alexander, please see the attached. For me, with live link, the VRscene object doesn’t render.
Or did you want me to raise a ticket?
temp.zip (5.16 MB)
Hi thomas_bussey,
It is working for me on my end, both with Live link and vrscene: https://drive.google.com/uc?id=1JeEuym6Xi06pPENavKa8ae1cL19n-Ukh
Does it render properly with V-Ray? Maybe the path to the vrscene is not accessible or has access restrictions.
Alexander
Yep renders fine in Max, CPU, GPU or IPR.
Are there any particular export requirements for vantage? Same user, I’ve check that vantage is being allowed through firewall (it wasn’t but that doesn’t seem to have fixed) Path is just just my desktop, so it should be alright!?
ah flippin’ 'eck. I’ve been using 1.8 all this time (only downloaded it to test and trial)
Upgraded and now it works!
Well now I have another odd one, many of the VRobject references are getting partially transformed when I import. Maybe this is something to do with the hierarchy, but they display and render fine in the source file.
Also works correctly if I bring the VRscene of the buildings straight in to Vantage, but there’s obviously no transform, and the lack of an align tool makes them impossible to position with any accuracy.
I can’t actually even find how to display world position, can only get local/world offset currently, otherwise I could just copy and paste the world positions to the directly imported reference.
Ok, here’s a simplified version of the issue. one VRScene object at origin, one transformed - both referenced to the same VRScene file. I export these to a new VRscene to capture the transform in max and the Railclone elements of the building on the one with the transform (pretty much everything but the floor slab) gets what looks like a double transform (i.e. offset again and rotated another 45 degrees)
By VRobject I guess you mean VRayScene ?
Where do you import them, in 3dsMax or Vantage ?
Maybe this is something to do with the hierarchy, but they display and render fine in the source file.​
I don’t quite understand what you mean by “but they display and render fine in the source file”.
Do you mean that the scene renders correctly in V-Ray, but not in Vantage ?
Can you attach or send us a max scene file (with the referenced vrscenes) that renders incorrectly in Vantage ?
Greetings,
Vladimir Nedev
In Vantage you can right-click on the Move/Scale/Rotate tool in the top toolbar and you will get transform type-ins similar to those in Max. The values are Coordinate type dependent so you can switch between World and Local: https://drive.google.com/uc?id=1bp4O2Fuw9ZWJ8-CjnAo1po98olJC19fP
Thank you for the reproduction. I have logged in our system and we will inform you when we have a fix for it.
Alexander
Yes sorry, I was trying to differentiate between the 3DSMax VrScene container object, and the *.vrscene file itself.
Do you mean that the scene renders correctly in V-Ray, but not in Vantage ?​
That’s correct so I modeled the building in 3DSMax (using Railclone and some native geometry), exported to a VRscene file, imported this to another 3DSMax file where I cloned and transformed them (displays and renders fine with Vray), and then exported that to a new VRscene file for bringing in to vantage (complete with lighting/cameras/other itoo objects & geometry).
I used this workflow (using VRScene as a container within a ‘master’ scene where it’s composed with other elements) for an animation rendered with Vray CPU and it worked great. I was able to edit the building in isolation, aligned to world, and not have to worry about composing multisub materials to capture all the materials in the building. It also gives me a nice, decimated mesh to lighten up my ‘master’ scene and (I think) maintained the instancing optimisation that railclone does where it can in the background.
Just as a test I just brought that building in isolation back in to the ‘master’ and the transforms are all messed up again, so definitely something to do with the export process rather than import in to Vantage.
I wonder if it’s something to do with the railclone objects in the original file not having their pivots at the origin​
Thank you for the explanation.
Like Alexander mentioned, he was able to reproduce the issue.
The VRayScene transform (from the master vrscene file) is applied twice to Instancer (RailClone,ForestPack,etc) objects in the referenced vrscene files.
It’s an issue with the VRayScene support in Vantage, we will try to have it fixed for the next Vantage patch.
Greetings,
Vladimir Nedev
It does appear to be an issue in 3DS Max as well then (not that I’m sure why you’d ever need to make a VRscene within a VRScene in max) but it’s the same thing happening as far as I can tell.
temp.zip (8.04 MB)
Hm, that might be something else, we will check the scene you attached.
Greetings,
Vladimir Nedev
Yes, that’s another issue entirely.
A VRayScene within a VRayScene is not supported in V-Ray (and Vantage follows this behavior).
There must be a bug in the preview code in 3dsMax, it should show nothing.
Greetings,
Vladimir Nedev
Hello. Is there any progress on this issue?
Vantage says it’s supported now, so is there any chance it will be incorporated also in vray itself?
