I’m having an issue with final renders in V-Ray. Interactive rendering works correctly, but when I render the exact same scene using the final render, the output is completely incorrect. Sometimes it renders entirely white, sometimes half white and half grass, sometimes completely black, or half black and half dark brown.
I occasionally get an error message saying that there is not enough memory on the graphics card. However, according to the performance metrics, the GPU is not being utilized at 100%.
Have any of you experienced a similar issue? Do you know how to fix it?
The problem occurs with only one specific file. I’ve also tried opening and rendering the file on another computer, but the results are still incorrect.
There is no difference whether I use CPU or GPU rendering.
