V-Ray spotlights not working when render
I cant get V-Ray spotlights to work. I have placed 2 spotlights in my bathroom scene but there are no light when I render and nothing happens when I change the intensity level. I can only see a very weak stream of light on the wall over the toilet from one of the spotlights.
What am I doing wrong? Im using Sketchup for Mac.
Hi @tom_stendahl ,
They do appear to be working from the screenshots provided.
When Spot Light is used, make sure to additionally adjust the Cone and Penumbra Angles and direct it towards a desired object or a surface. You may also want to try and play a bit with the Units. Try switching from Default to Radiant power (W), for example, and play with the intensity values. To read more about Spot Lights, please visit: V-Ray for SketchUp
Hi @nikoleta.garkova
No its not working if you look at the picture to the left which is rendered with V-Ray its too dark even though intensity is set on maximum. The light doesn’t change if I decrease the intensity only a smal beam of light. The picture to the right is not rendered and its only a Sketchup picture.
It worked if I changed the light to Radiant power (W) but still I cant figure out why default settings wont work?
Thank you for the help!
Hi Tom,
I have found that spotlights tend not to work when the tip of the cone is hidden in the ceiling or touching the ceiling.
When I lower the cones by 1mm for example, they suddenly work.
Maybe you can check if this is the case for you too?
Sincere greetings,
Sigrid
