V-Ray Swarm - Nodes stuck at "ENABLED"
Hey!
I’m trying to use V-Ray Swarm but I can’t get it working. When I start a render the nodes will only stay in “ENABLED” status. Sometimes a node quickly switches to “UNREACHABLE” and then back to “ENABLED”.
I dont know what “UNREACHABLE” means, there is surprisingly little technical information on V-Ray Swarm tbh.
My process:
1. Start “V-Ray Swarm (start service)” on all machines.
2. Start V-Ray UI on rendering machine.
3. In the Swarm UI I see the other nodes with stars attached to their names. The render machine doesn’t get a star. All machines say “ENABLED”.
4. Turn OFF the “Auto discovery” in Network Discovery and use 127.0.0.1 to be able to find the “default” tag.
5. Add the “default” tag in tags.
6. Start the render.
7. Nodes stay stuck in ENABLED and occasionally switches to UNREACHABLE and then back again to ENABLED.
I’ve tried auto discovery and it just wont work. Something is wrong.
BR
Elias
Hello, it will be best if you send us an email to support@chaosgroup.com so we could troubleshoot the issue. We`ll need your customer number and other info that is not advisable to be shared on the forums.
