Hey! I am trying to use the vray mix node with CUDA/RTX, but I can’t seem to get it working. It works fine when using the CPU and also with CUDA/RTX when I have a very simple material network, but for larger matnets it just outputs black when using CUDA/RTX. If I take the inputs to the mix node and output them as the base color of the surface material, then I can see the inputs are all perfectly fine, but the output of the mix node is still black. I recreated the mix node using OSL, but it gave the same output. Any help would be greatly appreciated! Please let me know if I can give more information.
Could you please send us some scenes showing the issue?
Hi. Thanks for the response. Yes no problem I’ll get back to you ASAP.
Hi, is it possible to send you the hip files directly?
Sure, there is an email in my forum signature.
