I did some testing recently for a client. They wanted to see a side-by-side of V-Ray in comparison to Enscape because they are considering upgrading from V-Ray 2.0 to 3.6 or Enscape 2.2. Below are the results I sent them.
In my example I’m using V-Ray 3.6 (V-Ray 2.0 is no longer supported and even slower) and Enscape 2.2. My computer has a 10-core 20-thread 4.2ghz CPU and a 1080ti GPU as well as 140 thread network farm. This gives you a reference as to the hardware I’m working with. So in my test here, you’ll see some slight color and contrast variation between the two images. I believe I can fix that in-scene if I tinker further, but for this example, I thought what I’ve produced was close enough and something that could be corrected with some color adjustments in Photoshop.
Now the big difference is the set up times and render times. The Enscape image took about 15 minutes to set up materials and rendered in about 30 seconds at a resolution of 4500x2379px. The V-Ray image took about 30 minutes to set up materials and rendered in about fifteen minutes (15m) on the default “High Quality” setting at 3000x1586px across 140 thread network, so you can see, its a substantial change in speed between the two images mainly because the V-Ray image renders on the CPU and the Enscape image renders on the GPU.
This may not be the most scientific example ever, but it definitely shows how much speed can be a factor, especially when designing.
