V-Ray Toon Material Solaris [HOU-3882]
Hello.
Does Vray Toon Material works in Solaris? As I tried it to add, but nothing happened, toon effect not added 19,5,569 Vray vray_adv_61009_houdini19.5.569_2bdc6c6_22432
Hello @Mikhalenko
Thank you for reaching out to us! The issue has been replicated on our side, classified as a bug (HOU-3882) and escalated to the Development team for further inspection and resolution.
We will post in this thread once the fix is available.
Hello @Mikhalenko
I glad to let you know that the Toon Material is now functioning in Solaris. Feel free to download the latest nightly and test it yoursefl: Chaos
Hello. Thanks! But in the latest build I don’t see version for Windows only for Mac Chaos
This is because you are not looking at the correct page. Please, download the latest Nightly build that is from 20.06.2023: https://nightlies.chaos.com/main#/vr…ghtly/20230620
Please, let me know what you see in that page. If it is empty, please, log out and log in again, then re-open the link. If it’s still empty you might not have the rights to view the Nightlies. Let me know and we will fix that.
Thanks. I tried steps that you discribe, and page seems empty. Can you please give permission? I will Direct Message you my actual user name
I saw you have been already given access couple of years ago. I sent a request to our system and the colleagues will check the situation. Your ticket number is
Maybe it was for old account. For current accout that I have send you in Direct Message I have acceses for nightlies but only stable versions, not nightly
Hello @Mikhalenko
You should now be able to access the Nightlies.
Enjoy you time with V-Ray
Thanks. Just tested. on CPU Toon Material seems work fine. but on GPU version it not work?
​Also I have a problem with geometry in Vray. On first screenshot is vray render. on second just Houdini viewport, and third is Karma. As you can see, in Vray there some problem on render
We are using standard triangulation methods from the USD library; if you render with Storm you’ll probably see the same issue. The only workaround for now is to add additional triangulation manually.
Hello @Mikhalenko
Please, note that the V-Ray Toon is only supported on CPU. You can find what is supported on GPU here: V-Ray for Houdini
Regarding the geometry issues you are facing, please, refer to Andrei’s (Bdancer) comment.
Hi, thank you for implementing this feature into Solaris, I do have one question, how do you get the edges to work? as I was reading the documentation I saw you need to add the toon effect to the Vray Enviroment Node, how do you do this in Solaris?
We are currently implementing the Toon effect support in Solaris; should be in the nightlies in a week or so.
