V2.6.0 Black screen when rendering
Similar to this thread: V2.6.0 - Cannot render Panorama - Black screen
Currently happening on two separate PCs, no artificial lights, immediately after V2.6 update. (which also reset all enscape settings ;( )
Anyone else experiencing this?
I was able to resolve this, here’s how:
1, Close the Enscape window
2. In the new General Settings, go to the “performance” tab and untick auto resolution
  1. (Optional) In the new Visual Settings, go to the “capture” tab and change the resolution to “Window”
  2. Reopen the Enscape window
This resolves the black screen and restores the render behaviour as per the previous version.
Hi @DanVinar
thanks a lot for your report! Did you try if the same issue still occurs with the 2.6.1-preview.2 version released on Friday? If it does, please let us know and send Feedback with your logfile and if possible it would help us tremendously if you could provide us with the project file where this is happening.
I’m having the same issues, I cant seem to get it back to working tho, every time I render the just get the black screen. After you close it down I can not get enscape window to open again. Have to close down and open the fole up again and give it another shot.
Huge fan of Enscape however its getting a bit frustrating, every time you update there seems to be a another issues that springs up that halts your workflow.
@DanVinar any help? using the most up to date Enscape.
This is currently a brick wall for a major deadline we are working on… we are unable to produce images.
Hello @Ollyt
We cannot tell much from this symptom alone. Please send the logs - black screen can be a result of a dozen of issues. Very probably it is GPU memory related, however.
The following can help if it is memory related:
  1. Capture in a lower resolution. If works perfectly every time - you are out of memory because of the capture resolution.
  2. If you have an RTX GPU - make sure you have the latest driver and try disabling RTX.
  3. Change rendering quality to “Draft” - it will also reduce memory consumption and will disable several rendering passes which could have issues.
These options may become a workaround for the urgent case. For better diagnostics - please send us the logs.
I installed enscape 2.6 and see what i get !
Kindly help
