V5 GPU - Multimatte through glass?
I render a lot of wristwatches and need masks of the complex dials behind the front glass. The material ID color isn’t working in GPU mode :frowning: and so I tried the object ID and multimatte object output - also not working. Is there a GPU based solution? If not, when it will come?
Hi Micha,
We’ll escalate this further so our development team can try to prioritize it and will let you know when we have more information in this regard. Internal ticket nr. is VGPU-826. Thanks for the understanding and patience!
Hi Micha,
If the glass refraction (bending) is not important for the images you render, you can try using the Fake Glass material from the library.
It uses opacity instead of Refraction and will pass the Mask colors even with the GPU engine.
Konstantin
@konstantin_chaos Thank you for the hint. Unfortunately full raytraced glass is needed, since the chamfered edges of the glass show refraction effects.
OK, you’ll need a V-Ray Core solution then.
I’ll make sure the GPU team is aware of this limitation.
Logged - VGPU-5334
@konstantin_chaos Has there been any movement on this? I am trying to have an object behind glass come through in an element channel.
Many Thanks!
-Greg
Hi
I totally agree, this is a major issue with vray gpu that needs to be adressed.
Is imposible to composite a house when You use RE. I use a Lot composite and render elements don’t go forward if You have a Window with glass material.
For architectural rendering this is a crucial thing.
I still miss it a lot here too.
The ‘fake glass’ approach that I suggested earlier should work OK for windows.
The original limitation has not been addressed yet.
Konstantin
Just the last feedback Konstantin about this subject, how Big is the difference using real glass and fake glass???
Do You have an example about this???
Also how light is coming without refraction???, are You sure we don’t loose Quality using fake glass??
I believe this is not going to look right, since this is not a real solution with realistic materials.
I can use fake glass for a temporary solution, but this is not a real solution, please bring a core solution too to vray for sketchup, this should be in every software support for glass material in RE.
I already talked with Muhhamed about this subject on vray gpu forums. So important for architecs and designers.
Thanks.
Right, fake glass is not a solution for jewelry and product design renderings. It’s an essential feature which should get a higher priority.
Hi guys, there is a fix in nightly builds now for the root issue. The next step is to fix render elements like Multimatte through glass
This topic has had our highest priority for a while. I will update the thread when I have more information to share
Best,
Muhammed
Hi Muhhamed
Since this a real feature that all vray gpu users are going to use i think is better that You and the vray gpu enginers take the time to full develop this feature.
If You can bring a Nice and practícal solution to this this is going to be huge Muhhamed, this is so crucial, with this new feature we can composite in the VFB as it should be… Full control on RE on composite for glass material.
So if we see the outside of the house from inside ( in a Window with glass material)we can have the complete control on reflections, speculars and lighting outside of the courtyard with a garden.
The same if i see the house from the outside to look inside ( with a Window and glass material) so we can change with RE the sub Surface scaterring materials, reflections, speculars, lighting and global ilumination.
Believe me Muhhamed this is going to be great for all vray gpu users. Not only vray gpu for sketchup and rhyno but all the users (maya, max, Houdini, Revit).
So there is no 1 mood for the outside and another mood for inside.
Just 1 mood for all the render scene Even with Windows or without Windows.
Take your time Muhhamed and please full develop this feature, i don’t care if it is for the next update or vray 6. I don’t want to ask anything since i understand Chaos group keep this things very secret. For me is fine… I like a Lot the surprises when You bring a new update on Youtube… Is like ohhhh wuaaa new features, new posibilities for a better render and of course to full develop architecture in spaces.
Keep things like that!!!
I Really appreciate the effort on this Muhhamed, so helpfull for vray gpu users, is going to be great to have the complete control on composite with VFB.
Thanks all Vray gpu team!!!
Best regards
Luis Gamino
Hi @luisgamino2 and thanks for the feedback as always :slight_smile:
I will discuss this topic this week in the Dev meeting, and I linked your reply to the issue thread in our tracking system
It is totally fine to ask and/or check the progress on the issues and requests your posted. Don’t worry about it :slight_smile:
Have a great day!
Best,
Muhammed
Same problems here (we are on 3DSMAX but it seems we got the same issues),
We do a LOT of jewelery and watches at the studio,
Since we are swapping from CPU to GPU, we have to find many workaround.
We miss a lot the “all channel” option for the AOV with the possibility to have mask behind refractive glasses and other refractive stuff (diamonds, gemstone etc.) and the other topic I’ve bumped recently about the AOV not going through VrayBlendMat.
Jewelery and watch is a lot about compositing passes (each material, each part got his own mask)
I know those fix are known and already in devellopement, I’m just pushing (a little) about the need we have around those issue.
Thanks again to the devs and the forum team again for the great work,
Best,
Nicolas
Hi @Nicolas_F
Both requests are near the top of the current priority list, the tasks are quite complicated on the development side. We will get there eventually
I will message here when I have more information
Best,
Muhammed
@Muhammed_Hamed How are you guys looking for a fix on this? It’s been about 4 months now since the last update and having this feature is important.
Thanks so much for your teams efforts!
-Greg
Hey @h3d
This is now solved in our internal builds, it will get released soon after it gets tested from our QA
@Micha @luisgamino2 as mentioned, this is now solved and will be released publicly soon
Best,
Muhammed
Hi @Muhammed_Hamed ,
I’ve just checked the 6.00.20 patch note (I still don’t own the Vray 6 upgrade)
V-Ray GPU
  • GPU support for Affect All Channels;
Is that new feature related to :
- Multimatte / Mask ID thought glass ?
- Mask ID thought VrayBlendMat ?
Thanks,
Nicolas​
