v6.0 CoronaSky MEdit preview trigger problem
when I move in viewport the CoronaSun disk to change, for example, from sunny day to sunset, I don’t see any changes in the MEdit preview until I modify some CoronaSky parameter.
It’s like CoronaSky is not trigged by the CoronaSun solar disk changes.
I think it is better to see the changes in real time also in the MEdit.
Can it be considered as a bug? =)
Thank you.
Hi, I just tested this, and it works like this:
  • Corona 5 - does not work at all - Corona Sky remains it its “default” appearance, even if I move the sun object around
  • Corona 6 18.06 daily - works correctly - Corona Sky automatically updates based on the position of the sun object in the viewport
It looks like we will need further info and/or screenshots or video recording.
Ok, you are right.
I will send you a video =)
To test:
  • slate material editor
  • compact material editor
  • max 2015
  • IR on / off
Update: happens in max 2015, does not happen in max 2020, 2021
Update 2: seems to be 3ds Max issue, moving to resolved, might try to fix
