v7 latest build bugs
I have downloaded the newest v7 build to check on some older issues I reported. I am happy to see that proxies now display bump and displacement. However, I am still experiencing some older issues I have reported before.
  1. Project Asset Inspector is unable to change paths of ies lights and proxies:
    https://forum.corona-renderer.com/ Relative Texture Path via Project Asset Inspector #msg176273
  2. When ies file’s path is set as relative, it will not function only absolute paths work:
    https://forum.corona-renderer.com/ ies lights not working with relative paths #msg176313
  3. When Proxies paths are set to relative viewport speed drops to few fps:
    https://forum.corona-renderer.com/ Viewport slows down lot after setting proxy´s path from absolute to relative. #msg163056
Although if you make the first issue function (project asset inspector), I can use absolute paths and work around two other problems.
Thank you for keeping corona great
Daniel
we are looking into it, some explanations in https://forum.corona-renderer.com/ relative folder path
Thanks,
Jan
