Valve Index Compatiblity?
Does Enscape need to release an update for the Revit plugin for the Valve Index, or is that something that will automatically happen via SteamVR?
If that’s something that needs to be coded on the developer level, is it something that Enscape is planning on doing since the Valve Index will be shipping around June 15, 2019?
@robert_grandmaison , since SteamVR should naturally support the Valve Index from the get go, Enscape should also support it straight away, although we may have to check on that because of the controllers, but it is generally planned to be fully supported in the future. :slight_smile:
