Vanishing components during render
Greetings all,
When rendering (generally after a crash or when Sketchup has frozen), the next time I render, a bunch of components in the scene just stop rendering, they cease to exist. It has happened with components I made myself as well as models I gathered from the 3D warehouse.
The components have all rendered wonderfully up until a point where for some reason, no matter what I do, they refuse to render unless I explode them (which then makes the model too huge to render easily).
When I take the component out, and put it in a new SketchUp environment, it renders fine, but pasting it back in the model, and it fails to manifest during the render process.
Is there any reason for this to occur? And how can I rectify it (it’s driving me nuts)
Re: Vanishing components during render
that used to happen a lot to me when i was still in the previous versions…
what version of vray for sketchup are you using?
i used to fix that by exploding everything
I downloaded it from the site a couple of weeks ago (I’m trying the trial version). Ungrouping things, and exploding the vegetation has helped, but I’m just wodnering why these things rendered each time and then suddenly for some reason, everything stops rendering after a certain point.
I’d like to try and find a way around exploding because I’m using it for design concepts on a building, and if I explode the components, its going to force me to recreate and alter everything one at a time, slowing me up considerably.
I have not seen this since 1.05.30. Can you post a sample model?
Also, exactly what is the version number of the VfSU you run?
You can download the demo from our site. If you download the demo from other sites (that aren’t resellers), there’s all sorts of possible problems that could arise. It could be some sort of really outdated or buggy version, it could be infected with viruses, the installer may be damaged, etc. In my opinion, don’t even bother messing with whatever version you have installed anymore. Uninstall it, and download the official version from our site.
