Vantage 2.6.1 Chaos Scatter not working
did i miss something in new version?
Tried a simple scatter scene - same. unless i convert scatter to max geometry
Upd.
tried even without link - still not working
Hi vray_team,
Chaos Scatter works as expected on my end. Which version of V-Ray and Scatter are you using? Can you show us an example of the setup?
Alexander
Hi Alexander
Thank you for response.
Here is a screen capture. you can see vray, scatter and 3dsmax versions.
and obviously, you can see result in vantage.
(i tried to create scatter in vrscene in vantage directly - it works, but its unacceptable for me as i have several different scatters in 3ds max scene already set up, so really need to find a reason why it doesnt appear in my vantage)
Thanks a lot!
Hi Pavel,
Can you please uninstall chaos scatter and then reinstall V-Ray, as I think this version of Scatter(6.0.4) is not compatible with V-Ray 6.2, it is compatible with V-Ray 7.? Please tell me if this solves the issue.
Alexander
Thank you, Alexander.
I will try to, but i dont think is incompatible.
It was installed with existing V-ray and works perfectly.
I dont think i will jump on V-Ray 7 as it’s beta (or just a first rev.)
UPD.
After V-Ray 7 installation it wirks.
It might be something wrong with my prev. scatter.
Thank you for help!
