Vantage 3 and still no proper bump support?
Hello guys,
I’ll keep banging the drum because I see this as a very basic thing to support. But we still have no proper bump mapping. I know you say bump is not properly supported in the shader graph… But what are you working on for a solution?
Adding a bump map, compositing them and stacking them procedurally is very common in texturing
Normal maps, yes, fast, but generally always rely on a bitmap with proper RGB values baked in. You can’t just plug black and white height values into the normal map as it wont work.
Vray CPU has a bump to normal texture map that helps with this exact problem - can’t you just support this map? Or create your own internal solution to generate a normal map from a height map if bump support is not an option for Vantage?
Bump with shading graphs won’t be in the initial 3.0 release, but we plan to look at it after that.
That’s basically adding support for bump with shading graphs, it’s the same thing.
That means baking the texture, which will create lots of problems with procedural textures, 3d mapping and combining different uv sets at different scales, so you won’t be happy again.
Greetings,
Vladimir Nedev
