Vantage 3 flickering
I’m running into flickering issues with my animation. Not sure what it is. I have a decent amount of samples. 600 for this example. Any idea? 3ds max 2026, Vantage 3.
Can you try rendering with the light cache disabled or increasing the light cache sample limit to 2000 or 4000 ?
Do you have any moving objects or lights in your scene (not in the camera view obviously, but somewhere else) ?
Those will cause the light cache to be reset on each frame and if the GI situation is complicated enough, each new version of the light cache will be different enough that you will see these splotches appearing and disappearing in different places.
Greetings,
Vladimir Nedev
I’ll look at the light cache option. No moving lights.
If I disable light cache won’t that give me a grainy solution?
Not if you have the denoiser enabled.
The denoiser will have to work with a noisier input and this itself could lead to flickering, but maybe it will do a better job than the light cache.
Greetings,
Vladimir Nedev
So… turned off LC, definitely helped with the light flicker. Samples set at 300 so there was some noise flickering. I’m going to run it again with LC on, and cache samples set to 4000. See if I get a clean result.
I don’t think anything has changed.
The flickering issue is very scene dependent, you need to have very noisy GI and moving objects/lights which cause the light cache to reset each frame.
Maybe you didn’t have moving objects in those previous scenes.
Greetings,
Vladimir Nedev
