Getting this crash a lot with my scenes that worked in 2.0. This is with the latest build..Not sure how to debug why it’s happening.. but I’m pretty much dead in the water
Are you using ‘x’ to level the camera before saving ?
If not, can you send us the .dmp file mentioned in the message box ?
Greetings,
Vladimir Nedev
Hi Vladimir. No, not using “X.” I sent the dmp file and vrscene throughs the support ticket system.
Is this after you upgraded Vantage? I was getting the dump crash too, but then upgraded.
I have the vrscene now, but just opening it and saving a .vantage file doesn’t reproduce the crash.
Are there any other steps before that ?
Do you have an associated .vantage file that you load and then the crash happens when you save it again ?
Can you send us this .vantage file as well ?
Greetings,
Vladimir Nedev
