vantage file not saving changes made inside vantage with live link
hi everyone
max 2025 and vantage 3.0.2 . my usual workflow is use live link from max . make post processing or other changes inside vantage and then save that vantage file. when reworking on that scene i simply load that vantage file as config again and everything is there, my color socrrection settings, scene states cameras made inside vantage etc.
but this one file is giving me trouble. i make the changes in vanatge file but when i reload it as config only its like a blank new file. no settings have been saved.
in the debug log i get this error
"18:54:57.946 [vrdx::loadRapidJSONDocFromFile] -2: Failed to parse JSON file D:/35 13/1.vantage (at 131072 bytes): Missing a closing quotation mark in string.
18:54:57.946 Error loading Vantage file D:/35 13/1.vantage: [vrdx::loadRapidJSONDocFromFile] -2: Failed to parse JSON file D:/35 13/1.vantage (at 131072 bytes): Missing a closing quotation mark in string.
i have tried everything. copy paste to new blank file or move file to shorter part in my SSD and other things that i read online but its still not resolved. please help me with this as i have around 20 cameras in scene and they all had scene states.
thanks
Can you send this file to support or attach it here or send it to my e-mail ?
Greetings,
Vladimir Nedev
i have emailed you 3dsmax archive . its 2025 version. subject of email is 3dsmax file
I need the 1.vantage file since that’s logged as corrupted.
Is it in the archive you sent me ?
Greetings,
Vladimir Nedev
i have emailed u few vantage files. 1.vantage was my attempt at using a clean file and fixing the truncated 1.vantage file. it worked but again got corrupted when saved .
see email. and read the email please.
thanks u so much for this
i used a file that was working and used notepadd++ to copy data from it to paste it to my corrupted file. it worked . but as soon as i used save as it started giving same error. so 1.vantage was that file
There are no .vantage files in “archives 3 november 2025.rar”, please send them separately.
Greetings,
Vladimir Nedev
i just emailed those to you now. i had missed attaching the files earlier
I can reproduce this incorrect behavior. Still investigating what causes it and which is the last Vantage version that worked correctly.
Greetings,
Vladimir Nedev
the 06.rar file i sent you works fine and shows all saved settings and scene states.
Yes, I got that.
But if I open and resave it even in Vantage 2.8.1 (during live link), the new file comes out corrupted.
So it seems to be a bug older than the 3.0 release.
Greetings,
Vladimir Nedev
yes that has been my whole issue. even if i load a working file as soon as save as or save it the corruption comes. i treied using vantage 2.8.1 also but in that also it starts giving problem as soon as save or save as happens
when can i expect the resolution for this as this is a current running project
We will be releasing a patch, hopefully tomorrow, which should have the fix.
After more investigating, the source of the problem is VRayCam001 - it’s somehow corrupted.
If you delete it in 3dsMax before starting the live link, saving the .vantage files should work (I haven’t tried this to confirm).
Even with the current builds.
Greetings,
Vladimir Nedev
awesome.it worked. infact there was one more camera vraycam002 that was corrupted. strangely when i select them i just see a gizmo in max and not an actual camera even if i do unhide all nothing is there but it still gets selected. whats the sorcery? anyhow thanks a lot for this. after deleting those 2 cameras the scene worked. i hope the patch will fix these kind of issues otherwise its not everyones cup of tea to troubleshoot this.
