vantage file size
Just to undderstand hhow it works, I exported a file with 100 frames and few objects moving. The vrscene file ends up being more than 100 giga, the max file was 500 mb. Does this mean that the size of the vantage file depends on the number of frames? So it’ s like having a certain size multiplied per each frame that has differences llike moving objects?
Most likely, you have some deforming mesh in your scene.
The .vrscene exporter will store a separate snapshot of the deforming meshes for each frame, which can make the .vrscene file very large.
Greetings,
Vladimir Nedev
I understood that deforming mesh weren’t even supported.
Deforming meshes are (currently) not supported in Vantage, but the .vrscene exporter is used for other stuff as well - rendering with V-Ray Standalone and rendering with V-Ray Cloud.
Greetings,
Vladimir Nedev
