vantage glitches in anima animation
hej,
every time im rendering out an animation in anima i get weird texture glitches. (see attched) anyone got an idea why? :slight_smile:
Are you rendering the animation through the live link or by opening a vrscene file ?
Is it possible to send an example scene that glitches to our support ?
Also, what are your Anima, V-Ray and Vantage versions ?
Greetings,
Vladimir Nedev
hej, thanks for the answer. i’m exporting it as vrscene animation and use all the newest versions. :slight_smile:
i sadly cant share the scenes.
i somewhat made it work though now through tewaking couple of export setting. i’ll let u know if the error occures again. :slight_smile:
What did you tweak ?
Greetings,
Vladimir Nedev
I am also very curious what you tweaked because i m exactly in the same situation… and the deadline gets closer and closer.
I would really appreciate if you could take 2 minutes to explain your steps :slight_smile:
I have found the issue. You must bake your animation in Anima (lock it) before exporting.
https://docs.axyz-design.com/article/baking-animations/
