I use vray on max, and everytime I try to either export as a livelink or static scene to Vantage, it crashes.
I use max 2024 - Vray 6 2.1 update - Vantage 2.5.2
I cant update either Vray or Vantage because my CPU is to old, so im stuck with these 2 versions.
By “static scene” do you mean a vrscene file? If you can share a scene that crashes we could try to find what causes it so you can avoid it while using an old build. You can create a ticket here: https://support.chaos.com/hc/en-us/requests/new Ideally use a smaller scene if possible and include all asset files used by it.
If you can’t share the scene you could try disabling/deleting parts of your scene until it stops causing a crash, to find what the specific cause is.
