How do i fix this continuous flickering issue in Vantage.https://youtu.be/lohT4GBZGbk
I am using 3DSMax
Can you give us more context? Are you using the latest version 2.5.2? What are you doing, is an animation playing? It looks like something is changing the scene and this resets sampling.
The sampling noise may improve if you enable “Direct light reservoir resampling” in the Render settings panel.
I am using the latest 3DSMax 2025, VRay 6, Vantage version, 2.5.2. I am working on a still render.
Constant flickering is not letting me interact with the scene in Vantage. It flickers even while rendering the scene.
Also, when live link is on, 3DSMax slows down after some time.
Strange, it looks like Vantage is getting some update over live link every ~3 seconds. I don’t know why. Does this happen if you start V-Ray GPU IPR instead?
yes, I noticed that too. i was going to open a topic for this now, I saw the title. there was nothing like this before 2.5.2. this is a problem that comes with the latest version. as if DLSS is not working
DLSS is only used in interactive mode. The issue reported above is in offline render mode. Are you having the same issue? Did it occur only when you updated to 2.5.2 (without updating V-Ray, etc.) ? If so, does it go away if you install 2.5.1 or 2.5.0 again?
Hi everyone,
Driver 552.44 didn’t help
Having the same issue with live link on my projects. No dlss on. What a pain.
Yes @Luma3d , this problem with VRayGPU
This problem has also occurred to me in versions prior to 2.6, and could only be solved by re-importing everything into a new project.
Nikita… what do you mean it’s vraygpu? Is there a setting in Vray 7 gpu that can be turned off or on to solve the issue? Or is it a bug in LiveLink?
Here is what I’m getting while editing my project while livelink is on: https://youtu.be/\_SMVKomwkOw
Dug a little deeper and noticed that if I turn off the tilt camera correction in 3ds max’s vray camera the flicker stops… works normal. I also noticed that if I have a physical camera in my scene, Vantage does not update as I move around in my viewport.
Vantage uses VRayGPU for work
@Luma3d thanks for the hint “Automatic vertical tilt”.
You need to disable “Automatic vertical tilt” (in instance cameras) or make cameras unique.
https://drive.google.com/file/d/1MxBt39lDdgdktG6EYU2c\_33szAcPzKwz/view?usp=sharing
To avoid confusion: Vantage does not use V-Ray GPU for *rendering*. It just uses the Max-to-VRay format exporter that is used by V-Ray GPU. This is necessary because the CPU engine of V-Ray in Max is different than in all other integrations (Maya, C4D, etc.) -- V-Ray CPU in Max is implemented using the 3ds Max API as an embedded native renderer and therefore does not have to translate the scene to V-Ray standalone format.
Nikola, thanks for the explanation ![]()
Figured… hence my confusion.
