Vantage makes me crash the RTX 5090
Good morning everyone, I have a problem with Vantage that appears randomly, but in the last day it has become serious. While Vantage is rendering, the PC crashes, but it is the VGA that crashes, I tried with a test on Cinebench2026 even very long, without problems. The card until a few days ago had no problems. Vantage makes me crash the VGA with any file, both complex and very small. I checked the event log of Win 11, and the error it gives me is that the Nvidia driver did not find the video card, this is because Vantage is crashing my card. Do you recommend formatting? Do you recommend disassembling the entire PC, cleaning it and then reassembling the PC? I’m out of ideas… What can I do to find the cause and solve it? Thanks everyone for the help .
FIlippo.
Win 11 + 9950x + 128gb ram + RTX 5090 Zotac o.c. (Nvidia driver 595.79)
If you suspect a hardware issue, you can apply general advice found elsewhere on the internet, such as checking the cooling, slot and cable connections, etc. Is your power supply adequate for this beefy card? You probably need 1000W+ (transient power spikes may need more power than the expected TDP - we’ve observed this with previous generation cards).
I would suggest trying an older driver, such as 591.xx or even older if there’s no change -- NVIDIA seems to have increased problems with drivers lately. Does the issue coincide with a driver upgrade?
Good morning, I’ll try installing the old drivers now and let you know if the problem persists. My power supply is a 1200W Asus ROG Strix, so I’m fine. I don’t know if it’s a hardware problem. I ran some benchmarks and tried running the GPU with ComfyUI, and I had no problems. At the moment, the problem only occurs with Vantage. Thanks for your help, I’ll keep you updated on the situation.
Filippo
Good morning, I installed the old Nvidia drivers, 591.74, and the situation seems better. I’ll update you if there are any new developments.
Thanks for your help.
Filippo
According to information provided by CHAOS, the recommended driver is 581.57.
Is this information still up to date or not ?
I think you are referring to V-Ray GPU driver recommendations. It does not apply to Vantage. We don’t recommend a specific driver. The minimum is 537. Newer drivers are generally better, but lately NVIDIA have issues with their drivers overall, like in games etc.
