So in c4d, I have an mp4 as a texture (v-ray texture with mp4 as self-illumination texture and using v-ray bake). When I use live link for Vantage, the mp4 does not play when scrubbing the timeline.
Is there a specific thing that needs to be enabled?
I am modeling an environmental scene and want to use Vantage to animate a walkthrough, and there is a specific object with a mp4 as texture that needs to be animated. It works in C4D when rendering individual frames at different points in the timeline (e.g. frame 1 vs frame 100), but in Vantage, it’s a still image.
Thanks! I have exported the mp4 as a jpg sequence and created a material where I added a vraybitmap to the diffuse channel, with the first image of the jpg sequence loaded, and the animation set to sequence. I copied this shader from the diffuse channel to the self-illumination channel.
I opened live link on Vantage but there is no animation (this is applied as a texture to a TV), it is just a still image. Is there another setting within Vantage that I need to change?
Is there something that I’m missing on the V-ray in C4D settings?
In your V-Ray material in Cinema4D, make sure to have the first frame of the sequence loaded in V-Ray Bitmap and have the animation start and end frame set accordingly, as shown here. Make sure that your sequence is not loaded inside a VRayC4Dbake shader.
Thanks for the reply! I have set the parameters as you said (please see the screenshot attachments in the above reply) but when I open this in either Live Link or .vrscene in Vantage, there is no animation sequence—it is just a still image. Is there another setting I should check? Either in C4D or within Vantage?
This works as expected on my end. Would you mind sharing a simplified scene where the issue is reproducible so we can have a look? Also, please share the exact versions of V-Ray, Vantage and Cinema4D that you have installed. Thanks.
Your scene works as expected on my end as you can see here with the same versions of V-Ray and Vantage. However, as I noticed that you are using an older versions, could you try installing the latest versions and see if that helps? If you continue to experience this issue, please open a support ticket so we can investigate further. Thanks.
Thanks, @aleksandar.kasabov ! When I do it they way you show in the video, scrubbing through the timeline in C4D, it works! However, the way I tried it was to animate a camera in Vantage, from Point A to Point B, with a transition time of x number of seconds, and when the camera animates, the video texture stays on the same frame and doesn’t play. How do I make it so that camera transition animations in Vantage play the video texture?
I am trying to animate a walkthrough through a space via Vantage because it renders much more quickly, whether via Live Link or exported as a .vrscene, but I’m having trouble with the video texture not playing within Vantage. It works when using Live Link the way you showed—is there a way to animate the camera in C4D and then export it and have it play in Vantage? I tried exporting as a .vrscene, but the camera seems stuck on the same frame, unless there is something I’m missing.
When exporting the vrscene, do you export animation (make sure to set your desired frame range in the Output section of the Render settings, as shown here, before exporting the vrscene)? When you bring this vrscene to Vantage, the animation will update when you scrub the timeline or when you render a High Quality Render. Keep in mind that the texture won’t update when you “Play” the animation until you “Pause” it, as we are not able to fetch the texture for each frame in real time. We might change this in the future.
Thank you! Your instructions allowed the video animation texture to work! I had to set the frame range when exporting, which was the missing piece.
On a separate note, maybe I will need to start a new topic, but is there a way to make textures appear correctly, as they do when rendering with V-ray in C4D? In Vantage, when certain textures that were set as Cubic or UW Mapping, do not appear to be applied correctly or appear at all in Vantage. Most times they are working, but sometimes, they are either cut or cropped, or flipped or mirrored, or just black. When rendered from C4D via V-ray, they are correct.
