Hi there,
I did read some other posts about similar issues but could not find exactly what I am facing.
The setup I am using:
Windows 10 PC with 2 graphic cards:
- RTX 2080
- GTX 980
- Nvida driver 466.27 (so above the Vantage recommended version, newer won´t do as the GTX card then has issues)
- Windows 10 version 1903
Both GPU cards do work fine in 3DsMax Vray (6.1) rendering as well as do work fine with Vray benchmark.
I did select the RTX 2080 card only in the Nvidia system settings for the Vantage software. And upon startup of vantage I am still getting the “No suitable GPU device found!” error message.
We inadvertently raised the requirements in version 1.8.4 due to a feature we are developing for the next major update that shouldn’t have affected this patch. You could try installing 1.8.3 instead (“show all versions” on the download page) or update your Windows to 2004 (a.k.a. 20H1, 19041) or later.
Hello. I have the same problem. All update for windows installed.
Windows specification: windows 10 enterprise ltsc. Version 1809. OS build 17763.4010
I have - RTX 2080 . Nvidia Studio Driver 517.40
Yes, any newer update should work. The increased requirement is a bug in 1.8.4 and should be reverted when we release the next patch 1.8.5. If you can’t update Windows just download 1.8.3 from here (use all versions checkbox) Download | My Chaos
