Vantage script installation on 3ds Max other than non-English UI
The Chaos Vantage installer only copies the Vantage MAX Script under the “ENU” folder.
C:\Users\\AppData\Local\Autodesk\3dsMax\2021 - 64bit\ENU\
Therefore, if the user is using a language UI other than English, the Chaos Vantage script will not be visible.
(I know it can be used by copying from ENU to another language folder.)
The installer should detect all local language folders and copy the script.
MAX Support Lang is “CHS”,“DEU”,“FRA”,“JPN”,“KOR”
I checked Chaos Vantage, v1.0.2.
The 3ds Max scripts are still copied only to the /ENU/ folder.
Do Chaos Vantage representatives see my advice?
Hi flat,
Yes, we thank you for your feedback and your request has been logged. Unfortunately I cannot give you an ETA for that. I will bump the priority so that it may be fixed in the next release.
Alexander
