1: Probably not - render in passes instead. You’ll get innacurate gi though.
2: You can’t since vray has its own reflection type and those controls aren’t available.
3: Your scene is really far away from 0,0,0 - it means you might get some inaccuracies with rays missing objects far away - might slow down scenes a bit. might also happen with scenes that have huge scale - stuff like autocad imports of big developments.
4: Far as I know yes, it was an issue a while back but they got it sorted.
actually I think you can, both via max’s and vray’s objects properties. if I understand the question correctly.
I think I remember there might be a problem (I remember having some weird dots showing up in a couple of cases), but you could sort it out unchecking “max-compatible shadecontext” in the system rollout.
but I guess John’s right and it’s now sorted.
1. It’s possible yes, vray completely supports standard max lights, just press the “exclude” button on the modify panel with the light selected.
2. I believe RC4 has support for excluding objects from reflections, although Vray does reflections very fast and I personally have not found it necessary to do this.
3. CTRL-A, Group->group, F12, 0, 0, 0, should help fix this warning
4. Yes, no problems here ever.
