VBF Compare issue?
This is tough to explain. (TYPO IN TITLE…SHOULD BE VFB)
I render a sequence, and use the stand alone denoiser on them. This strips the images of render passes but only rgb and alpha I think.
When I need to go back into a scene and make changes and compare the new render to an image in the sequence, this is challenging.
I render a new still denoised version that has all the render passes, but then when I compare, the new still is using the effects channel or the Denoised channel, but is trying to compare to the SA denoised sequence frame which has only the RGB (which is denoised)…VFB doesn’t compare these two difference channels. Anyway to fix this?
Let me know if I didn’t explain this well enough.
