hello,
Is it possible to safe VBF automatically just like Render output?.
Reason : Once the render was okayish, I pressed stop and clicked save VBF and Max crashed, although, the render was saved using Render output as a .tiff file. But if Auto VBF is possible, I could open the render and clean up a region area. Now I am just re-rendering the selected area to make it suitable. I know its not ideal, but generally it seems to work for naughty areas, when quick renders are needed.
Thanks.
Autosave already there. Look for it in system tab, IIRC.
ooopps I just clicked it on while rendering, not a good idea.
Thanks Romullus.
Crashes should never happen, if you experience crashes - no matter how you did it - please report them!
hmzz, but how would I know it is do with the render engine.
I experience crashes probably in these three categories.
- Scatter
- Complex materials, during loading textures or playing around with settings.
- Sometimes while modelling.
- During render save, not anymore after using auto save.
edit : mostly happens on my low spec system, never experienced it on a workstation.
