VCM not so efficient with blurry refractions? (fireflies bzzzzzz)
I’m new here and verry impressed thus far!
I was verry curious to see how the newish VCM method would perform (this is the main reason i decided to try corona).
Most tests i’ve seen use perfect glossy reflections/refractions and i find glossy/blurry glass sexy, i thought id test for myself how vcm handles it.
I found out it seems to be quite less efficient with blurry glass…
…or is it a bug? I wonder, because the fireflies have strange positioning (surrounding the object like a glow?)
Anyway, from all the tests i’ve seen with VCM i thought this render should’ve been ‘done’ by now, but clearly its not… (still rendering though, havent cancelled it yet).
Maybe it’s me doing it wrong? Mostly using default settings though…
i have a small request/suggestion regarding this too: something like vray’s ‘affect shadows’ option for refractive materials would be verry usefull for fast transparent shadows!
this is most definitely a bug, can you post the scene?
Sure, here it is.
I cleaned it up a little; removed hidden objects, layers and unused maps. I also converted the glass object to an editable mesh (it was an npower nurbs object).
The settings i changed (and that i remember) are:
Main corona settings:
  • max ray depth to 50
  • use bdir with vcm
  • mat editor quality to 10
  • change location of primary solver to d: (c: is my ssd so i dont like it being spammed with writes)
    Depth of field/Motion blur settings
    fstop to 2
    sensor width to 36mm
    VFB Settings:
    Display AA to 2
    Renderer: PT/VCM:
    initial lookup radius to 3
Hope you can replicate it and find the little troublemaker!
CoronaGlassTest.rar (5.55 MB)
Please don’t make me look bad and fix this ASAP :smiley:
Are you open to a little extortion? :smiley:
Had some more time to play around and apperently, the dof is also acting rather strange…
Heres the exact same scene, but i replaced the glass material with a near white diffuse one.
Left: dof on
Right: dof off
This time rendered using bdpt
Maybe its related to the other problem?
With that last one?
Notice the hazy/foggy look around the dof… especially at the top of the object, where it is brightest.
Its almost like a glow or ghosting of the object going on.
I think some dof samples might be spread too much out or something?
Those last 2 (with the white diffuse shader) were done with bdpt, the vcm option was not selected.
Do not use DOF with VCM, it not working properly.
Bulgarian technology! :stuck_out_tongue:
Fixed
Awesome! I guess i cant download the version with the fix (yet?)
