Vdenoise EXR compression
Does vdenoise output EXRs with the same compression type as the input file/s?
If so how does that affect input EXRs using a lossy compression type? I assume you get a denoised but slightly degraded output?
All input welcomed.
Cheers,
Olly
At the moment we use ZIPS compression for the output files, I believe, so no quality is lost, but we might have to add some options for this.
