VDenoise plugin for NUKE
Is it possible to update the VDenoise plugin for NUKE to work with Nuke 11.2 (Latest). Thank you kindly.
It’s already updated already; if you go to
and re-download the .zip file, it should contain versions for Nuke 11.2
Hi Vlado, thank you all working perfectly.
Regards
Would it be possible to get a version of the VDenoise plug-in for Nuke 11.3 ? We’re actually using Nuke 11.3v1 on Windows. The most recent build in the download package is for Nuke 11.2.
Thanks so much.
- Bill
We actually have it recompiled, we have to update the file in the docs section. In the meantime you can email me to vlado@chaosgroup.com and I’ll get it to you.
Since you are asking for the plugin, I assume you are using it. Any comments/suggestions? Is it working well for you?
For me, it works brilliantly. I usually shuffle out all my render elements for more control over each light select element, reflections, refraction’s etc. Then I can apply the denoise node before bringing them back together. I have greater control then to apply variable strength denoiser to each element. For example reflections may have more cleanup than the others. I can get away with rendering with a noise threshold of somewhere between 0.02 and 0.05 in vray, depending on the scene, which is an incredible reduction in render times, especially on a GPU setup.
This plugin is key to my final stage of working. Thank you for this!!
Hi Vlado,
I couldn’t have said it better.
We have been using VDenoise since October and it not only provides very good quality results, it also reduces our render times substantially. I sent you an email directly requesting a copy of the plug-in.
Thanks. This plug-in is really helping us!
Is it possible to update it for NUKE 12v2?
If you download the files again, there should be a Nuke 12 version as well.
Cheers,
That’s great!! thanks.
could this be complied for nume 12.1? thanks
There should already be a 12.1 version uploaded at the same place V-Ray Tools
