vdenoise tool - EXR output file size
In older vdenoise for vray 3.4, the denoised EXR is without render element, which makes the size of the file convenient, and the render element is saved separately as jpg.
In newer vray versions, the denosied EXR file size is very large with render element, even if i did not save the render element separately, in Adobe aftereffect the importing of every render element from the EXR file is not the easiest workflow in tight deadlines.
the new denoise tool need to have the option to choose between 1- EXR without render element (smaller file size)
        2- EXR with render element
Thanks.
Hi @Ali_Essawy
This is added as an improvement request under: VMAX-10760 - we will let you know when there are any updates on the matter.
