Dear Chaosgroup,
we are currently shifting from V-Ray 3.7 to V-Ray 5 but are still using V-Ray 3.7 as legacy.
But we know there is a possibility to use the Denoise Multipass in V-Ray 3.7. I tried to save renderings including these renderelements which are have to be saved for
the Vdenoise.exe Tool but had no luck. I can see this Renderelements in the 3.7 V-Ray Framebuffer but there seem not to be saved when using the Cinema Pictureviewer and also not when
using V-Ray Framebuffer with “Translator → Save VFB Images”.
And because its an animation, it will not help to save them manually out of the VFB.
What do I do wrong? How can I save those necessary denoising Renderelements such as: “noiseLevel”, “defocusAmount”, “worldnormals” etc.?
thx in advance!
Edit: OK I found out that when saving it as .vrimg it saves those elements. But when using the denoiser-tool it says:
“error: [DenoiserApp::readMultiChannel] 0: Error the image file is incomplete, the data of channel “Sub-pixel weight” is missing”
Is it because V-Ray 3.7 does not have this channel? Or how do I set this up in V-Ray?
PdZ
