Vectorworks and batch rendering
Hi!
Before I get crazy… can I perform a batch rendering using VW?
And if yes, how… 8)
Thank you
L.
@Toscano , please ensure you’re using one of our recent releases or the latest release itself, and check out this article section here:
https://learn.enscape3d.com/blog/knowledgebase/administer_favorite_views-win-revit/#batch
Hope that helps! :slight_smile:
I’m sorry… it was just a distraction…
Speaking about batch render: is there some way to name the files as:
Step_01
Step_02
and so on…
Thank you
L.
Hey @Toscano
The only way to do that is by naming the views you select for the batch render process accordingly. If you have further ideas for a more detailed naming system, please feel free to share them directly with our product management team here:
https://portal.productboard.com/enscape3d/7-enscape-portal/tabs/17-under-consideration
Thank you!
Hi Kaj !
Thank you for your reply.
I’m sorry, but it doesn’t works. The way you wrote, works with the picture not with panos.
I’ve already check for that.
Anyway, thank you again. Hope to hear from you very soon.
L.
You didn’t mention panos in your earlier posts …. Naughty
Batch saving panos is a pita in SU too, I’m trying to write a program to speed the process but a solution from Enscape would be a better answer.
Thank you, Paul !
L.
