Velocity Measurement
I am working on a simulation for images that will be presented at a sensitive Court Trail using Pheonix fluid simulation.
I need to know in the " liquid emitter “, what is the outgoing velocity measurement using as its base unit? For instance, in my scene, my default outgoing Velocity is 600.00”.
Does this mean each particle that is emitted will move at 600" per second?
I need to match up these values to measurements our experts have taken. An example of the data I need to match would be 60 Cubic Feet per second.
Or is the outgoing velocity 600" measurement something else?
Thank you
Hey,
The liquid source will emit in units per second when the Source is in Surface Force mode. It will use the system units that you have specified in your Max settings.
The displayed units will change accordingly if you change the system scene units.
Cheers!
