Hello everybody,
i have a problem with velvet texture on chaos vantage.
Like you can see in the images preview, i have no problem to render a velvet texture on vray. But i lose all fall-off and sheen property when i render on chaos vantage.
Can tou help me plz ?
Thank you.
Y
Maybe because it unsupported (if you use sheen in that case)
All unsupported features a here Chaos Vantage
Indeed, its not on the list, list that i forgot to read.
Thx.
Y
Hi Mala_suerte,
We will add support for the sheen layer at some point. As a workaround, you could use a combination of a Falloff map in the reflection slot and noise in the glossiness slot. It will produce somewhat similar results. Let me know if this works.
Simeon
Thank you for your answer and sorry for mine, because it is late. Here’s what it looks like using your method.
The Fall off effect is still too weak but better than my first test.
