Enscape isn’t a modeling software so what geometry are you trying to export? Other then exporting standalone files I’m not aware of any export feature Enscape has.
If you use 3.3 and while performing View Management, click the help button the last entry is “Export Geometry” which refers to a toggle switch that does not exist for me using 3.3 for Sketchup.
It doesn’t exist because SketchUp uses the same geometry across the whole file - so the initial export (when you press the play button) contains everything you need.
I would assume it’s there for Revitt because each one of those 3D views is like having multiple SketchUp files open.
@renderwiz , as already halfway stated above by Adam, this has mainly been implemented for Revit indeed and is not required nor available for SketchUp in this case. We may want to exclude that info in the help dialogue to avoid confusion, so I’ll forward it as feedback.
