I’m having the same problem. proxies are rendering correctly but in Rhino viewport some of them are wrongly positioned, scaled and also distorted.
When the fix will be available? This is quite urgent.
This is exactly the same issue.
We’ll do our best to put out a hotfix that resolves it as soon as possible.
Thank you.
Hi guys,
This issue is fixed in V-Ray 5 for Rhino, update 1.3
Excuse us for the inconvenience and let us know if you find any related issues.
Konstantin
Hi ALTO,
I was not able to reproduce the described behavior.
Can you share a simple example scene that does this for you?
Also, does it happen with new scenes?
Konstantin
Hi Kostantin, as i said the scene you see in the screenshots was already sent to chaos support, ticket 341-813-5371
It looks ok in new scenes.
OK, that’s great.
I’ll get back to you as soon as possible.
Konstantin,
Could you please check also this vrscene AM_Cars_03_03 in the same file? It looks wrong in Vision:
Wow…
Guys I am having the same issue! This is terrible. I have large files with many proxy trees and they have been thrown all over the place. Impossible to work with. The update has made things worse. Do we know if reverting back to previous version of Vray might help? I have a deadline soon approaching and lots to do.
Hi guys,
We’ve just released a hotfix that addresses the main issues discussed here - the no objects visible in the viewport thing (caused by the proxy preview scaling code).
Konstantin
