I’m using C4D R19 on Mac.
Installed Corona Ver. 6
Now the Interactive Window won’t close once it’s opened.
I need to restart C4D to get rid of it.
And when the Interactive Render Window is open, it only shows a portion of the image.
I need to use the slider bars to see the whole image.
See attached.
we are aware of his issue that some of the users already reported earlier, however it is irreproducible on our end and apparently happens only to a handful of users.
To help us dealing with this issue, could you, please, write the following info:
C4D Version:
OS Version:
Computer specs:
Thanks for the cooperation,
Jan
Hi Jan.
Here is my info -
C4D R19.068
macOS Catalina Version 10.15.7
iMac Pro (2017)
Processor: 3.2 GHz 8-Core Intel Xeon W
Memory: 32 GB 2666 MHz DDR4
Graphics: Radeon Pro Vega 56 8 GB
Hope that helps ![]()
Just upgraded to MACOS Big Sur and still having the same problem.
Just upgraded to C4D R23 and am no longer having this issue ![]()
did you also update corona to the latest daily build? There have been some internal changes that might fix this issue.
