Vertex Color Map
Please add support Vertex Color Map. [Rhono/SketchUp/Revit]
To render the vertex color of the Proxy object.
Hello, Yuji,
Thank you for your suggestion!
This is something doable, although it probably will not be a poplar feature. I discussed it with my colleagues and we will consider it, nevertheless.
Could you please describe what you want to use it for and how you imagine implementing it in your workflow?
Kind regards,
Peter
It is mainly for rendering ZBrush data.
I am requesting to support vertex color in ply2vrmesh below.
V-RaySketchUp / Rhino is an good environment for ZBrush users to easily perform realistic rendering. (3ds Max and Maya are expensive)
KeyShot is also a good product, but I want to sell V-Ray.
Thank you for your reply!
We’re still discussing a proposed solution and the benefits of its implementation in V-Ray for SketchUp. Will get back to you when we have it properly functioning in an internal build.
Kind regards,
Peter
