Vertex Colour/Materials
I’m trying to convert a Vray model to Corona - the Vray model was done in GrowFX utilising it’s Vertex Colour features.
The original Vray material’s diffuse map was a composite with Vertex Colour as the bottom layer and a greyscale leaf texture in the second layer set to Overlay 100%.
If I try to recreate just the diffuse map in Corona the material previews are wildly different.
I’ve attached the two - Vray is how it should look.
Anyone know what’s happening?
Did you use CoronaMix node? If so, did you tried to check/uncheck perform mixing in sRGB mode?
I initially just did it a composite map as per the original - i then tried the Corona mix with that option both checked and unchecked - all 3 gave me the same result
Could you check if vertex colours are still working? Maybe it get lost somehow?
I’ll check this later and let you know
