I’m trying to use a vertex map in one of my Corona shaders to add dirt, but it looks like it doesn’t work with Corona?
So under Opacity, I add layer, then shader->effects->vertex shader.
Please let me know if it works with Corona
wow yours look exactly the way i want, but yes, no luck this side.
Do you mind sharing the file so i can see your setup beanzvision?
Thank for the quick response
I updated my answer with mat setup. But feel free to look at the scene.
Vertexmap_scene_2.c4d (662 KB)
awesome! Thank you. Much appreciated!
All good man! ![]()
Just wanted to add that this can also work with the layered material for those not wanting to stack materials directly to the object.
thats awesome thank you
