I’m trying to use an background map (360 pict of sky in ‘spherical environ’ mode) in the environment slot with some vertical shift from a vrayphysicalcam. The vertical shift only seems to ‘shift’ the geometry. Is there any way for the vertical shift to also ‘shift’ the background image? (I’m trying to keep the horizons lined up).
Thanks,
Ryan
