I know this has been covered before but I can find the post. We are seeign a lot off issues with the vertical shift in the Vray camera in animations.
There was mention of a fix?
We are still on Max 9 and Vray SP 1.
All 64 Bit.
Cheers
Mike Kennedy
You can email me for a fix, if you wish; a work-around would be to not use the “Guess vertical shift” button, but to select the values manually when 3ds Max is in Animation mode.
I’ve some “viewport problem” if i use VRayCam.
For example, sometimes, if i’m in camera view, after i press F to front view, drag a rectangle… boom! The viewport come back to VRayCam…
Bye
cecofuli
I think that’s more of a 3ds Max issue - a viewport may switch to Perspective/Camera all by itself; this happens even without V-Ray installed. It was supposed to be fixed with the 3ds Max 2009 service pack.
Hi Vlado, good to know. But i work with 3ds max 2009 SP1 ![]()
bye
cecofuli
Ah, then obviously it wasn’t fixed ![]()
