We can not animate the Vertical Shift on VRAY Cameras, any chance of this being included in a newer version?
Cheers
Mike Kennedy
It will be added, yes.
Hmm, it works here.
If you set the vertical shift value by hand (dragging, typing) during auto key is on, it will work as expected, only the “guess vertical shift” button fails to do that. And it’s best to start from frame 0, and add keyframes to every single frame, even to those not changing at all, otherwise some odd thing can happen, but this might be Max related, and a VRay bug.
best regards,
A.
