Vertical Tilt Turning on During Animation Render
Hi all.
I have a strange issue which I’ve noticed when rendering sky passes but now am seeing it in main renders.
I’m not sure if it’s a corona thing, max thing, our render manager or all of them :smiley:
We’re using automatic vertical tilt for some shots that need it but the shots in question have it turned off. Yet mid shot it seems to turn back on.
I’ve checked the camera and there isn’t a keyframe or anything for the affected areas where you see it happening.
This is my every 15th test I did last night.
Now… I kind of know why it’s happening… but I don’t
The frames where this happens are the start of our render manager ‘chunks’ where a system has picked up a new range to render.
It’s as if max is being loaded and the vertical tilt of a previous shot is being looked at and applied.
To fix this yesterday when I had the issue with the sky, I just put 1 system on the whole of the affected shot.
I can’t do this with the main renders cos it’ll take too long.
Does anyone have any suggestions?
