Very easy to see fading on the ceiling
Hi
I’m trying to create a simple image, and I get a very distinctly grading in the ceiling.
I tried both png, jpg, exr and tga format. Same result.
Is there a way to avoid that?
Jorgensen
you could try adding a subtle (noise) texture and fading it, or a >0.1 level bump.
I think, a rendering should be without banding/leveling. I hope a fix will be possible.
Hey @Jorgensen_dk , to get behind the cause of this behavior, could you please send us the project at hand and the corresponding settings you’ve used while rendering this image? You can find your saved settings here: C:\Users<YOUR_USERNAME>\Documents\Enscape\Settings.
That would be very helpful. Thank you in advance! :slight_smile:
Hi @Demian_Gutberlet
Sorry - i deleted the file :frowning:
Jorgensen
No problem. If you experience this problem again, please be so kind as to send me the corresponding project and settings used. :slight_smile:
The color banding will be reduced in the upcoming release.
First question, Is the banding happening in the saved image or Enscape window? If the banding is in the image, it looks like an 8 bit issue. 8 bit images have less color information so the banding occurs. 16 and 32 bit images contains tons of color information so that the user can adjust the heck out of it and never see banding, Professional vis artist save out 32 bit .exr files just for this reason. However you can get away with 16 bit images. Enscape allows user to capture images in png, jpg, open exr, and tga. Maybe save out a open exr file and see it it helps.
I think tried with all formats - same result.
Jorgensen
The banding does not occur during the image saving, it happens in an Enscape internal intermediate buffer.
